I need to receive a 32-bit signed integer that is used for computations. I am aware that it might be represented with some loss of information if I put it in a register but that is a cceptable (Max integer value in Numerical Register). The bits of the 32-bit value is read in two 16-bit GI's (unsigned integers), and then needs to be 'reconstructed' as a 32-bit signed integer and I am struggling to do so.
For 16-bit unsigned/signed conversion, the following thread posts some options to do so:
Signed integer 16 bit
There may be negative numbers sent.
In the fanuc the group inputs and the registers where the GI's are copied are unsigned integers.
What is the best way to get signed integers in my register?
However, these methods in my case would require computations with an unsigned 32-bit integer range (2**32) which is not representible in FANUC/KAREL as far as I know. Are there any other methods for me to use? Short of mapping the 32-bit signed integer to individual DI's and then reconstructing* the value myself, I'm out of ideas.
*while on the topic of reconstruction, does FANUC (or KAREL specifically) use two's complement representation of signed integers?
