IRVision - Camera Data Calibration
  • AlexMac
  • March 25, 2024 at 8:07 PM
  • AlexMac
    49
    Hello esteemed colleagues!
    I am trying to automate the Camera Calibration Data on IRVision 2D by running the following commands:
    17:  VISION CAMERA_CALIB 'UF_TEST' Request=1 ;
    18:L PR[100:zero] 100mm/sec FINE Offset,PR[4:offset]    ;
    19:  VISION CAMERA_CALIB 'UF_TEST' Request=2 ;
    The thing is, I noticed that the Position of Cal. Grid Relative to App. UFrame does not update automatically when I run the commands above (see attached). So if I change the UF the calibration will run with no errors however all the results will be wrong, because the frame of reference is not the same as before.
    How can I fix this? I could not find the System Variable nor the command to update this parameter.
    Images
      • 119.11 kB
      • 1,920 × 529
      • 8
  • AlexMac
    49
    • March 25, 2024 at 8:58 PM
    • Best Answer
    Tuns out that if you set the request code to 100 on the Vision Camera_Calib instruction it will refresh the UF.
Similar Threads
  • iRVision Accuracy
    • edimmy
    • August 7, 2023 at 3:58 PM
    • Fanuc Robot Forum
  • INTP-281 "no application data"
    • emcstang
    • May 11, 2023 at 1:26 PM
    • Fanuc Robot Forum
  • Fanuc SCARA 2d Camera Vision
    • RobCat
    • January 21, 2022 at 9:39 AM
    • Fanuc Robot Forum
  • IrVision 2d
