  4. other Robots
help with program pallettizing
  • marino_desantis
  • March 18, 2024 at 8:48 PM
  • marino_desantis
    Good morning everyone,
    I have to make a program for the palletization of pallets, the palletization will be parameterized by an external PLC via variables.
    I need an example of a palletizing program with storage:
    -first piece deposited at 0 degrees
    -second deposited piece rotated 90 degrees
    I thank you in advance
  • Roland Keller March 18, 2024 at 8:51 PM
    Approved the thread.
  • Roland Keller
    13
    5
    66
    • March 18, 2024 at 8:53 PM
    Maybe you should add which robot it is
  • SkyeFire
    1,060
    9,456
    • March 19, 2024 at 2:07 PM
    Quote from marino_desantis
    I need an example of a palletizing program with storage: -first piece deposited at 0 degrees -second deposited piece rotated 90 degrees
    What about the 3rd piece? The 4th? The 97th? Palletizing can be very simple, or insanely complex. You need to provide much more detail before anyone can provide a useful answer.
    It would also be very helpful to know which robot you're using.
  • marino_desantis
    • March 19, 2024 at 8:58 PM
    sorry, I didn't write the model of the robot, it's a hyundai hs220 with hi5a controller
    the palletization will be deposited once at 0 degrees (zero degrees meaning a position relative to the base)
    the second rotated 90 degrees with respect to rx, the third at 0 degrees, the fourth at 90 degrees and so on until the end
  • SkyeFire
    1,060
    9,456
    • March 19, 2024 at 10:14 PM
    Is there a reason you're putting your message into Code frames instead of typing normally?
    Is X axis vertical? What is it the axis of? The Base? The Tool?
    Is this a linear tower? There's no lateral offset between these objects?
    If your TCP is centered on the object the robot is carrying, then simply programming two points -- one at 0deg, one at 90deg but one object higher, then performing a X axis offset every 2 parts would probably be sufficient.
    That I can't help with much, having no knowledge of how Hyundai robots perform offset math.
  • saberlars
    Robot, beyond Human..
    22
    239
    • March 20, 2024 at 2:45 PM
    (Grid pitch 100mm)
    ' Get current stack quantity from PLC
    V10% = GI4
    ' Calculate Indexing
    LV10% = (V10% MOD 4)
    ' Layer to Layer Offset (Height 300mm)
    LV13% = (V10 / 4) * 300
    ' Define Stack pattern by Index
    IF LV10% = 0 THEN
      LV11% = 0 ' X Offset
      LV12% = 0 ' Y Offset
      LV16% = 0 ' Rz Offset
    ElseIF LV10% = 1 THEN
      LV11% = -100
      LV12% = 500
      LV16% = 90
    ElseIF LV10% = 2 THEN
      LV11% = 500
      LV12% = 600
      LV16% = -180
    ElseIF LV10% = 3 THEN
      LV11% = 500
      LV12% = 100
      LV16% = -90
    EndIF
    ' Create Local Offset with Robot Base frame
    LR10 = (LV11%, LV12%, LV13%, 0, 0, LV16%)R
    ' RefPos(P10) & Offset(LR10) Mix
    LP1 = P10 + LR10
    LR11 = (0, 0, 200, 0, 0, 0)R ' Offset for Approach
    LR12 = (0, 0, 50, 0, 0, 0)R ' Offset for Approach
    S1 MOVE P, LP1 + LR1, S=50%, A=3, T=0
    S2 MOVE L, LP1 + LR2, S=20%, A=1, T=0
    S3 MOVE L, LP1, S=5%, A=0, T=0
    ' Gripper Do Signal Control
    S4 MOVE L, LP1 + LR2, S=10%, A=1, T=0
    S5 MOVE L, LP1 + LR1, S=50%, A=3, T=0
    I'm not sure this code working.
    anyway, Palletize key point is ROW, COLUMN, LAYER value assign to Offset Register.
    ABB, FANUC, Hyundai, Kawasaki
    Edited once, last by saberlars (March 20, 2024 at 2:58 PM).
  • Hyundai
