  4. Kawasaki Robot Forum
E_Con TCP/IP Communication question.
  • saberlars
  • March 16, 2024 at 1:45 AM
  • saberlars
    Robot, beyond Human..
    22
    223
    Hi KAWASAKI forum!
    Previous data communication experiences were all based on the RS232C(Serial) method.
    I'm never used TCP/IP communication.
    That code based on Chapter 6.2.2 of the 90210-1248DEB.pdf manual, but I am not sure if it will work properly.
    also, I hadn't any OLP program.
    Please let me know if there are any areas that need improvement or if you have any advice. Thank you.
    .PROGRAM ip_connect()
    ; Client(Rob) connection request to Server(PC)
    ; Server Port Define
      svr_port = 10000
    ; Server IP Define
      svr_ip[1] = 192
      svr_ip[2] = 168
      svr_ip[3] = 125
      svr_ip[4] = 200
    ; Timeout /sec
      timeup = 10
      TIMER (2) = 0
      TCP_CONNECT svr_id, svr_port, svr_ip[1], timeup
      IF svr_id = 0 THEN
        PRINT "_"
        PRINT ".Prog Ip_Connect"
        PRINT "Connection Error"
        STOP
      ELSE
        PRINT "_"
        PRINT "TCP/iP Established!"
        PRINT "Server ID= ", svr_id
        PRINT "Taken Time= ", TIMER(2)
      END
    .END
    .PROGRAM data_recv()
    ; Data Receive from Server
    ; Return ID (for Status Check)
      rtn_id = 0
    ; Define String Length
      str_length = 255
    ; Data's array count starting num
      recv_ary = 1
    ; Timeout /sec
      timeup = 10
      TIMER(3) = 0
      TCP_RECV rtn_id, svr_id, $recv_data[1], recv_ary, timeup, str_length
      IF rtn_id <> 0 THEN
        PRINT ""
        PRINT ".Prog Data_Get"
        PRINT "Data Receive Error= ", rtn_id
        STOP
      ELSE
        IF recv_ary > 0 THEN
          IF (recv_ary * max_length) <= 255 THEN
            PRINT ""
            PRINT "Data Recv OK"
            PRINT "Number of array : ", recv_ary
            PRINT "Final Raw data= ", $recv_data[1]
            PRINT "Taken Time= ", TIMER(3)
            $align = $recv_data[1]
          ELSE
            PRINT ""
            PRINT "String too long= ", recv_ary
            PRINT $recv_data[1]
            STOP
          END
        END
      END
    .END
    .PROGRAM data_send()
    ; String send to Server
    ; Get Model number from PLC
      WAIT BITS(1057,8) <> 0
      model = BITS(1057, 8)
    ; Trigger String Define
    ; "START" + "01" = "START01"
      $img_num[1] = "01"
      $img_num[2] = "02"
      $header = "START"
      $send_str[1] = $header + $img_num[model]
    ; Send String ($send_str) Array Index
      start_idx = 1
      rtn_id = 0
    ; Timeout /sec
      timeup = 10
      TIMER(4) = 0
      TCP_SEND rtn_id, svr_id, $send_str[1], start_idx, timeup
      IF rtn_id <> 0 THEN
        PRINT ""
        PRINT ".Prog Data_Send"
        PRINT "Data Send Error= ", rtn_id
        STOP
      ELSE
        PRINT ""
        PRINT "Data Send OK"
        PRINT "Sent String= ", $send_str[1]
        PRINT "Taken Time= ", TIMER(4)
      END
    .END
    .PROGRAM ip_close()
    ; TCP Connection Terminate
      rtn_id = 0
      TCP_CLOSE rtn_id, svr_id
      IF rtn_id <> 0 THEN
        PRINT ""
        PRINT ".Prog Ip_Close"
        PRINT "TCP Close Error= ", svr_id
        STOP
      ELSE
        PRINT ""
        PRINT "TCP Close OK"
      END
    .END
    ABB, FANUC, Hyundai, Kawasaki
  • Go to Best Answer
  • Alexandru
    49
    407
    • March 16, 2024 at 4:37 PM
    what you want to send on TCP/IP?
  • saberlars
    22
    223
    • March 16, 2024 at 5:57 PM
    Quote from Alexandru
    Server is “3D Vision PC" and camera will mount fixed bracket. (Above robot)
    I hope TCP/iP communicate as like a RS232C.
    Rob > PC "Trigger" (Request snapshot string)
    PC > Rob "Result" (Ok or NG & Coord Align string)
    Vision PC is operation thru Customized program.
    Different retail product. (ie - Cognex)
  • kwakisaki
    694
    4,763
    • March 17, 2024 at 11:09 AM
    Code is full of syntax errors on all your IF statements.
    Get KRoset and Hercules applications and you can test as much TCP/IP as you can eat.
  • saberlars
    22
    223
    • March 17, 2024 at 8:05 PM
    Quote from kwakisaki
    space character error.. right?
  • kwakisaki
    694
    4,763
    • March 17, 2024 at 9:12 PM
    No...............parentheses.
    Remember an IF is an evaluation expression of condition(s).
    Kawasaki does not care about spaces or tabs.
  • saberlars
    22
    223
    • March 17, 2024 at 9:48 PM
    I found wrong syntax expression!
    (TIMER statement lost =)
    (IF statement = -> ==)
    and upload confirmed K-iDE & K-ROSET!
    Thanks!
    Edited once, last by saberlars (March 17, 2024 at 10:13 PM).
  • kwakisaki
    694
    4,763
    • March 17, 2024 at 10:51 PM
    • Best Answer
    If you get Hercules application too, you can test data exchange like in attached video examples.
    Files
    KROSET TCP_IP Basic connection.mp4 3.04 MB – 43 Downloads KROSET TCP_IP and Hercules Tests.mp4 7.24 MB – 38 Downloads KROSET TCP_IP Pitfalls with Hercules.mp4 19.51 MB – 40 Downloads
  • saberlars
    22
    223
    • March 18, 2024 at 1:40 AM
    Yes Yes! It is really good for begineer!
    Have a nice day! :guru:
  • TCPIP
