Sending Outputs afther the line has past
  • kristofv
  • March 4, 2024 at 10:05 AM
  • kristofv
    51
    Hello to all.
    I was wondering.
    I have a welding source connected to the YRC1000.
    It give's me information when a welding error occurs. (gas failure, wire failure, voltage failure, ....)
    These signals are also available as general inputs and outputs in the YRC1000 to send to an external PLC so that the entire machine knows when there is a problem.
    However,
    If I program the robot to weld a line from point A to point B I could do the following:
    If input.... = on then set output.... = on (check welding errors)
    movement lines to point A
    arc on command
    movement to point B
    arc off command
    However if I would do it like this, the robot would check the inputs before and afther the weld which is no use.
    Can i check an input and send an output during welding (because the robot reads the program line by line).
    Hope this make sense :grinning_face_with_smiling_eyes:
    This is what i do, that doesn't mean it's the right way to do it. :smiling_face:
  • Robodoc
    56
    7
    1,059
    • March 9, 2024 at 2:25 PM
    Yes, You need the parallel job function and run the two jobs at the same time. One that welds and one that checks the status of the inputs and does something if it's not correct.
    Robodoc
  • kristofv
    51
    • March 11, 2024 at 8:51 AM
    Is it also possible that this happens directly true a written ladder?
  • roboprof
    24
    469
    • March 11, 2024 at 1:26 PM
    No, you need concurrent job to do this. It's a purchasable software option.
  • outputs
