Hello, I have basic knowledge in robotics and I am starting to configure a KUKA KRC2 robot that has a digital input and output module with Interbus protocol through external control with a Siemens PLC. My question is how do I make it so that when I enter a program number on the HMI, that program number is sent to the robot, I have not been able to understand how to send through these instructions: PGNO(number+parity) and PGNO_VALID(READ COMMAND).
Send a program number for the KUKA robot to execute from a Siemens PLC to a KRC2 with digital input and output modules using Interbus.
lino jelvez -
February 15, 2024 at 3:00 PM -
Lemster68
February 15, 2024 at 3:03 PM Approved the thread. -
First: do you have the Interbus connection working? Can you send and receive $INs and $OUTs over the Interbus connection?
Interbus is a Master/Slave bus system. Who is Master and who is Slave?
KUKA and Siemens also mean to swap low and high byte (on kuka side) - otherwise you will get wrong values.
What input and output modules are you using (normally only slave card and master card is needed)?
As SkyeFire mentioned:
make sure Interbus is workingproper outputs are sent and read as proper input
And after that start dealing with your EXT configuration
If you don't want to use Automatic External functionality you can declare signal that includes bits of position number from PLC :
SIGNAL PosNumber $IN[1] TO $IN[n]
You can declare it locally in declaration part of your submodule or in config.dat file as global variable
why is lino jelvez not able to answer my question from post #3?
