  4. ABB Robot Forum
Circular Move around an Object IRB6700
  • SimoneCosti
  • February 8, 2024 at 10:48 AM
  • SimoneCosti
    10
    Good morning everyone,
    Actually i'm working in a robotic cell where i need to rotate the tool of my robot around a cylindrical object.
    In this figure i will show you an example:
    I'm working with a workobject "temp_wobj" and i start from the robtarget "P_Start".
    The revolution around the object is approximately 80 degrees (but it may vary based on a certain input) and during the movement i should keep the point of the tool perpendicular to the surface.
    I think i can use a MoveC instruction but i don't know how i can define the final target "P_Fine"
    I thought i could define it with RelTool(P_Start,-Radius,0,-Radius,\Rx:=0,\Ry:=-80,\Rz:=0) but with this instruction the rotation occurs around the tool and not around the "temp_wobj" as i want.
    How can i define this point without taking it manually? My starting data are only the temp_wobj, the P_Start, the diameter of the object and the degrees.
  • Go to Best Answer
  • Lemster68
    301
    2,490
    Blog Articles
    7
    • February 8, 2024 at 2:13 PM
    You can combine the Reltool and Offset functions. There was discussion about that here:
    Move RelTool for x and y Axis
    I am in the process of automating pick and place applications and have unfortunately encountered a problem that I need help with.
    forums.robotstudio.com
    Black
    127
    • February 18, 2024 at 12:18 AM
    • Best Answer
    i used to made a perfect weld circle
    moveCirInc 47,7;
    MODULE Unnamed
    PROC CirInc(
    num raggio,
    num inclina)
    CirPathMode \CirPointOri;
    centro:=CRobT(\Tool:=tFRONIUS\WObj:=wATTUALE);
    moveL RelTool(centro,0,raggio,0\Rx:=-inclina\Ry:=inclina\Rz:=0),v200,fine,tFRONIUS\Wobj:=wATTUALE;
    moveC RelTool(centro,raggio,0,0\Rx:=inclina\Ry:=-inclina\Rz:=0),RelTool(centro,0,-raggio,0\Rx:=+inclina\Ry:=-inclina\Rz:=0),v200,z1,tFRONIUS\Wobj:=wATTUALE;
    moveC RelTool(centro,-raggio,0,0\Rx:=-inclina\Ry:=-inclina\Rz:=0),RelTool(centro,0,raggio,0\Rx:=-inclina\Ry:=inclina\Rz:=0),v200,z1,tFRONIUS\Wobj:=wATTUALE;
    moveL RelTool(centro,4,raggio,0\Rx:=0\Ry:=inclina\Rz:=0),v200,fine,tFRONIUS\Wobj:=wATTUALE;
    MoveL RelTool(centro,0,0,-30\Rx:=0\Ry:=0\Rz:=0),v500,z1,tFRONIUS\WObj:=wATTUALE;
    RETURN;
    ENDPROC
    ! moveCirInc 47,7;
    ENDMODULE
    Black
    127
    • February 18, 2024 at 12:35 AM
    you must define center point
  • SimoneCosti February 20, 2024 at 8:24 AM
    Selected a post as the best answer.
  • moveC
  • wobj
