Hi guys, I can't put images in the roboguide, I've already tried several things, even uninstalling, does anyone know how I can fix this? I need this for a test in which a picture will be painted, and in this test this painting added as a part needs to have an image
I can't put an image in a part
ThiagoSaoPauloSkills -
February 7, 2024 at 3:14 PM -
Lemster68
February 7, 2024 at 3:15 PM Approved the thread. -
Starting off, post what things you've tried and where specifically you're having issue, what step of the importing process into roboguide are you hitting your roadblock? what file type are you trying to import into roboguide?
hopefully this helps:
Add PART--> choose BOX --> switch to Image-Tab --> choose image and direction
Sorry guys, I was offline but I'm back, I installed version 9.3, and only sometimes the image works on old workcells that I didn't create, but it almost always doesn't work, I've tried the same thing that PnsStarter said but it didn't work, I think it could be some configuration, do you know anything?
I've already uninstalled the roboguide and installed it again, but it doesn't work again and the image I try to place I've already changed from JPG to BMP but it didn't work, and the dimensions I've put in the same as the part but didn't work
