Offset with PR along the axis of the UF of the current point
  • MoEL
  • November 15, 2023 at 10:34 AM
  • MoEL
    109
    I would like to make an offset from the current point along the X axis of the same UserFrame in the point.
    What I understood from my reserches is that the offset with the PR is allong world axis.
    Is that posible?
    Thank you
  • Foxtrot2050
    48
    • November 15, 2023 at 12:52 PM
    If I am understanding you correctly, yes you would make a PR offset then attach it to that point to make the offset work correctly. Then in the future if something needs moved you could in theory make those adjustments in the Offset and be good to go :grinning_face_with_smiling_eyes: . We use this all the time for our adhesive paths since we have panels that come in bent up.
  • hermann
    407
    2,612
    • November 15, 2023 at 2:47 PM
    Quote from MoEL
    .. What I understood from my reserches is that the offset with the PR is allong world axis....
    No. When you give an offset in a movement instruction, this instruction is done with actual tool frame in the actual user frame. So the offset also describes the offset in the actual user frame.
  • HalbesYoyo
    Persona non grata
    47
    151
    • November 15, 2023 at 2:57 PM
    Hi MoEL,
    you can use offsets according to world, any uframe or any tool:
      PR[99,1:temp_99]=200
      PR[99,2:temp_99]=0
      PR[99,3:temp_99]=0
      PR[99,4:temp_99]=0
      PR[99,5:temp_99]=0
      PR[99,6:temp_99]=0
      ! Offset in world
      UFRAME_NUM=0
      UTOOL_NUM=1
    J P[1] 100% FINE Offset,PR[99:temp_99]
      ! Offset in uframe 1
      UFRAME_NUM=1
      UTOOL_NUM=2
      ! Offset in tool 3
      UFRAME_NUM=1
      UTOOL_NUM=3
    J P[1] 100% FINE Tool_Offset,PR[99:temp_99]
    If you'd like to use the menu to change the UFRAME to world you may chose
    [MENU] > [SETUP] > [Frames] > [OTHER] > [User Frame] > [CLRIND]
    to clear the $MNUFRAMENUM (= set to zero) or you chose
    [MENU] > [SETUP] > [Frames] > [OTHER] > [User Frame] > [SETIND]
    to set to a specific UFRAME number.
    Be aware, that UFRAME and UTOOL for Positions (P in program) are stored along with the other values of the position. Using Position Registers (PR in program) will use the currently set UFRAME and UTOOL (indicated by the F).
    Edited once, last by HalbesYoyo (November 15, 2023 at 3:12 PM).
  • MoEL
    109
    • November 16, 2023 at 3:48 PM
    Quote from HalbesYoyo
    Hi MoEL,
      PR[99,2:temp_99]=0
      PR[99,3:temp_99]=0
      PR[99,4:temp_99]=0
      PR[99,5:temp_99]=0
      PR[99,6:temp_99]=0
      ! Offset in world
      UFRAME_NUM=0
      UTOOL_NUM=1
      UFRAME_NUM=1
      UTOOL_NUM=2
      ! Offset in tool 3
      UFRAME_NUM=1
      UTOOL_NUM=3
    This is a master class explanation,
    Thank you all
Similar Threads
  • Finding Distance between two positions with probe.
    • El Zapato
    • January 27, 2023 at 5:06 AM
    • Fanuc Robot Forum
  • Down the rabbit hole...Who wants to join in the fun?
    • Elderwild
    • November 30, 2021 at 8:25 PM
    • ABB Robot Forum
  • Very peculiar path bug... or possibly haunted robot
    • WhyDoesMyRobotHateMe
    • February 21, 2020 at 7:41 PM
    • Yaskawa Motoman Robot Forum
Users Viewing This Thread
  • 1 Guest
