When I try to load the interface panel onto the robot from my project opened in K-IDE an error occurs. It's a robot from the company I work for and it works fine, model FS030L-A001. I was wondering if it could be a problem due to the fact that the interface panel is running on the display so it doesn't allow me to change it. I thought about this since the same problem occurs when you modify a running program or an autostart program and they need to be aborted and killed.
What I did was just editing a pilot lamp signal and then I clicked "send interface panel to robot". Is there something wrong or missing from what I did?
Best regards,
Mariangelo
Error when loading interface panel to robot
Mariangelo Franzini -
October 23, 2023 at 8:43 PM -
MOM
October 23, 2023 at 9:41 PM Approved the thread. -
the interface panel code can be found in the robot backup at the section
.INTER_PANEL_D
.END
For example a pilot lamp code would like this this:
12,1,""," PICK 1 ","","",10,15,4,2,1073,0
What error code do you have when you try to load?
Interface Panel is not protected from being rewritten like programs.
So IFP pages, buttons can be changed freely just by reloading IFP data as Alexandru has stated.
Have a look at the attached video I made of IFP setup for alternative languages using KRoset IDE application, this is similar environment to KIDE.
I suspect the issue you have is how you are using KIDE.
You can visit the KIDE forum here and see if they have any further information for you:
Unfortunately I am unable to provide you with a real time video of what I did at work. But this short video sums up my actions.
The KIDE version in the video is 1.1.3.0 but at work I got 1.1.1.0. Could it be that my problem is caused by the fact that I am using an old version of the program? Also, could the fact that the controller is switched on bother the upload?
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
I would ask at the KIDE forum as you are using a VERY OLD ROBOT MODEL and it may not be fully supported.
This post suggests this:
The solution was using a newer version of K-IDE, I used version 1.1.3.0 and the bug was no longer present
