Change speed between points while retaining continual motion
eilevb -
October 16, 2023 at 8:34 PM -
- Go to Best Answer
Lemster68
October 16, 2023 at 8:36 PM Approved the thread. -
Have you tried to use the CONTINUE instruction? It should force the pointer to move forward, just insert it before the ÕV_PRO instruction and check if this still happens.
Also... if you need to do it with a fixed value on the movement, why don't you use the $VEL.CP instruction?
Also, check this thread: Kuka LIN Motion Dynamic Speed
Skyefire provides a hint on how you can do this if you need to do this adjustment on the fly, but it seems you may need to control the speed using the SPS in order to adjust the override speed on the fly, not by editing the speed directly on the path program.
CONTINUE command would cause the $OV_PRO change well in advance (well, $ADVANCE) of where it's programmed.
If you don't want to use the SPS, using a TRIGGER command to set $OV_PRO should be a workable option.
- Best Answer
Thanks!
For some reason this threw an exception: "$OV_PRO variable write-protected in module .."
Code$OV_PRO = 50 LIN_REL {X 100} C_DIS TRIGGER WHEN PATH=0 ONSTART DELAY=10 DO $OV_PRO=10 LIN_REL {Y 100}
I had to wrap the command in a sub-program for it to work
Interesting! I've never run into that before. But as the sub-program TRIGGER call seems to work, I guess it's not a big problem.
You are changing the speed between two movements, so why hassling with ov_pro and triggers? So:
