I'm still working on getting my machine running. Specs are below. The machine starts up fine now ... the motherboard has been replaced and the ESC card has been replaced. Replacing the ESC Card seems to have solved the problem I was having with the External Safety Switch being tripped when I don't have one. Also, the Operation Mode is now properly displayed on the KCP.
So now the problem is ... the KCP seems to be frozen. None of the buttons work. If I turn the operation mode switch from T1 to T2 the screen does not change ... still says T1. If I press the configure button to select the user group, nothing happens.
I had this happen a few times before I replaced the ESC Card, but I could always fix it by restarting the machine. This does not seem to be working now.
KUKA KR210 circa. 2003
KRC2 controller (not edition 5)
Thanks in advance for your thoughts.
