Variable write protected
  • madrjo3_RP
  • August 10, 2023 at 11:17 PM
  • madrjo3_RP
    27
    hi
    kuka
    kr30l
    kss8.6.6
    Does anyone know how I can change the properties of this variable to be able to write it, I mean to remove the protection
    Regards
    Saludos / Best Regards
    Madrijo3
  • Fubini
    282
    1,903
    • August 11, 2023 at 5:00 AM
    You can not do this. That is hard coded in the controller software. But maybe we can provide a different solution if you tell us what is the underlying problem you need to solve.
    Fubini
  • MOM
    176
    7
    1,424
    • August 11, 2023 at 7:26 AM
    This has something to do with SPOC (Single Point Of Control).
    Only the Program itself can change the value (e. .g. using an interrupt)
Similar Threads
  • Move a kuka robot using py_openshowvar
    • robotics_Cat_1242
    • April 4, 2023 at 12:06 PM
    • KUKA Robot Forum
  • Variable/ field write-protected
    • ASIJordan
    • September 28, 2019 at 2:45 PM
    • Fanuc Robot Forum
  • Write to $IN variable from KUKAVarProxy
    • coolafabbe
    • November 10, 2022 at 9:32 AM
    • KUKA Robot Forum
  • "Precision Robot: Model Deviation Too Large" Error or KRC2
    • Julian Sander
    • July 14, 2022 at 6:58 PM
    • KUKA Robot Forum
  • Start Robot KUKA with module KRL
    • Alexis Moctezuma
    • April 27, 2022 at 4:12 PM
    • KUKA Robot Forum
  • Signal Decleration Variable Write Protected Issue - How can I use the values of signal declaration variables ?
    • Zadok the priest
    • April 27, 2022 at 9:23 AM
    • KUKA Robot Forum
  • how to control kuka using python
    • ehabhti
    • November 22, 2021 at 11:41 PM
    • KUKA Robot Forum
  • System Variable Write Protect
    • Dabake14
    • August 27, 2021 at 11:08 PM
    • Fanuc Robot Forum
  • Trying to write Cutter Compensation
    • djb
    • August 17, 2021 at 10:32 PM
    • KUKA Robot Forum
  • handling
  • spot weld
  • KRC 2
