Hello all. I have my cell completed and am trying to download it to the actual robot. This is an R30iA controller. I assumed I just select export then point it toward the robots IP address however, when I do, I get this. Am I missing a step? Do I need to save it as a project, and that's why it doesn't show up in the projects field? Thank you
Trying to download from RG to Robot via E-net IP
ceilingwalker -
August 8, 2023 at 8:30 PM -
I should probably also add, it is the HandlingPRO project I am trying to export.
It's been a long time since I messed with that export option. Just learn how to FTP files to the robot and forget using RoboGuide to export. That's all it is doing in the background anyway.
When I FTP files, is that using UDC-1, for example? I have another Fanuc Robot that is R30iB and I use PalletPRO. It has a very simple method of uploading and downloading to the robot. It allows one to go in and individually select which files one wants to move. Would you happen to know if this is because it is an iA vs. iB thing or is it specific to PalletPRO?
Standard ftp, you want the directory: /md:\ in the robot. /md:\ is how I have it in WinSCP, something like Filezilla may be something like /md or some variation.
Anonymous login is fine, no encryption, port 21
