I am having a compatibility issue with KUKA WorkVisual and Windows 11, and I'm curious whether or not this is a common problem with other KUKA users. I have downloaded the latest version (6.0) as well as tried to run compatibility mode on my PC (to test if it works for older versions of Windows), but nothing has worked. The program can successfully be downloaded, but when I try to open it, nothing appears to happen. No errors pop up either. I also verified this to be the case with Task Manager. Does anyone have any suggestions or has anyone run into this problem.
Thanks,
Joseph
