How to get TCP position with Motoman driver?
  • arisigor
  • June 15, 2023 at 5:57 PM
  • arisigor
    10
    I'm using ROS Motoman Driver to communicate with Yaskawa robot. I was able to get the robot position through /joint_states topic using both terminal and python. But, I cannot find how do I get the TCP position?
  • Lemster68 June 15, 2023 at 6:11 PM
    Approved the thread.
  • Emre64
    59
    • July 8, 2023 at 3:15 PM
    Can you explain how you used ROS Motoman Driver in your controller?
    Where you use it in Python?
  • ljuba
    33
    5
    281
    • July 8, 2023 at 4:27 PM
    check this out
    moto/examples at main · ra-mtp-ntnu/moto
    A Python library for controlling Yaskawa MOTOMAN robots. - moto/examples at main · ra-mtp-ntnu/moto
    github.com
  • massula
    205
    8
    1,439
    • July 8, 2023 at 7:30 PM
    Quote from arisigor
    Looking at the driver documentation, If I understood correctly, by default it uses JointTrajectoryPoint type messages. But since ROS is open source, I believe with some tinkering would be possible to obtain the type of information You want, using tf2_ros (ROS2) node, for example.
    By the way, is always good inform what version/distribution of ROS You are using, since there are always changes between them.
  • Python
  • ROS
  • yaskawa hc10
