How should i assesmble this gimble,,,
2-Axis Brushless Drone Camera Gimbal with Controller
robogig -
June 12, 2023 at 12:05 PM -
panic mode
June 12, 2023 at 2:23 PM Approved the thread. -
panic mode
June 12, 2023 at 2:24 PM Moved the thread from forum General Discussion of Industrial Robots Only to forum General Robotics Discussions - everything but NO Industrial Robots. -
It is not kit in pieces - it is already assembled, ready for mounting
Google the balancing process. Some version of this. If the COG of the camera is not where it was designed to be then there will be shake in the gimble. They are pretty easy if you are using the camera it was designed for. Alternatively, you can also go into the firmware and edit the control settings with the SDK if the mass of your camera is very different to the designed camera. Its been too long since I tried it, but its feasible. An easy way to eat up a weekend.
