Command gear torque A1 error
  • capital9
  • June 8, 2023 at 11:32 AM
  • capital9
    71
    Hello guys,
    I am working with a KRC5 V 8.7.4 with KR150 robot and a linear track KL4000(external axes).
    I was calibrating Tool for which I defined load data of tool and defined the location for Centre of mass and their inertias. Then I was defining transformation using XYZ 4 point method. I successfully touched up 3 points from 3 direction without any errors, then while doing the last touch up point, there was “command gear torque A1” with error code KSS01073. Because of the same error none of the axis can jogged not even the external axes/ linear track. I tried the start-up mode and still get same error.
    Is there any particular reason for this? Since all the other 3 touch up points were fine with the same load data how come the last one has problem? Or is this because of some other reason?
  • Okami
    74
    • June 8, 2023 at 1:25 PM
    Copyied from the KSS error manual:
    ERROR 1073 Commanded gear torque
    CauseThe permissible gear torque has been exceeded.
    EfectPath--maintaining braking.
    All active commands inhibited.
    Output “$Alarm_STOP” is set to signal level 0.
    RemedyVerify load data.
    Reduce load if necessary.
    Reduce programmed acceleration.
    Reduce programmed velocity.
    Acknowledge message.
    "Hell...Yesterday it was workinG... I sweaR" :o)
  • capital9
    71
    • June 8, 2023 at 2:00 PM
    Okami i read that error message. i am using a 35 kgs tool and robot supports 150 kg. i have defined the tool as it should be like other cases. it was working for all the 3 touch up point until the last one.
    even after defining the tool it gives error that means there is something i am missing not because of weight but because of possibly something else maybe linear track/KL4000 (E1) axis but i am not sure what is the actual reason.
  • Fubini
    278
    1,886
    • June 8, 2023 at 2:56 PM
    Did you check load data when error happens, $load_c? Is the expected tool active, $tool_c? Does the error happen while jogging or while running a program. How is your KL setup? Is the KL measured in? Does the error come immediatly even with override zero or very small? Whats the holding torque, $Holding_torque[]? Is this value plausible? Is the robot new or was something modified recently? If it was modified whats the difference when comparing machine data to the old configuration, r1/$machine.dat and $robcor.dat? Do the brakes open when you push tbe deadman switch, clicking noise? Are the axis values the robot thinks it has fit approximatly to the actual position, $axis_act? Is the current cartesian position plausible, $pos_act? Is the robot absolute accurate and mounted tilted on the KL? Does the error persist even after cold boot?
    Especially A1 is often the case if the robot is configured to be wall mounted but actually is floor mounted.
    Too many possibilities without knowing more details about what situation you actually have there.
    Fubini
  • capital9
    71
    • June 27, 2023 at 9:24 AM
    Fubini
    There was a problem with transformation of the Linear track, basically there was no standared transformation for linear track. when i changed the linear tracks transformation into standard the problem did not occur after that. so possibly robot could have been wall mounted configuration, which is weird as the robot was never ordered like that from KUKA.
    But hey i am having problem making the linear track as asynchronous axis.
    1) First thing i tried is disable transformation and activated asychronous axis for E1. After safety configuration, i always end up having following errors:
    KSS12032 Position deviation motion controller<>safety controller
    KSS00404 Safety stop
    this says there is some mismatch in configuration between safety controller and machine data and suggest me to update the safety configuration.
    i figured out the difference was with $ET1_TFLA3.A and $ET1_TFLA3.C
    i did safety configuration to match them yet the error stays.
    2) Another thing i tried was enable coupling of the linear axis and making the linear axis asynchronous, and disabling the transformation. this helped me to get rid of position deviation error but the safety stop error was not cleared.
    i believe the reason lies within transformation of linear track and robot. but i could not figure out how to get proper configuration. or it could be completely different things.
  • Fubini
    278
    1,886
    • June 27, 2023 at 11:39 AM
    You mean your robot is mounted on a linear track and you want to decouple both? Kinematically coupled axes like KLs can not be made asynchronous. How is the KL configured in r1/$machine.dat? Is it of type #ERSYS? Then making it async will not work. So what exactly are you trying to achieve here? Normally KL is for use cases where you extend your robot from 6 dof to 7 dof by the KL. So basically setting ERSYS-mode tells the system to treat robot and KL as a unit with some specific redundancy handling.
    Maybe thios helps on how the KL is calculated
    Post
    Re: 2 external axis+ceiling robot
    the transformation chain for any external kinematic is (see R1/$machine.dat)
    $ETn_TA1KR(Ex1) : $ET1_TA2A1(Ex2) : $ETn_TA2A1(Ex3) : ETn_TFLA3, n = 1,..., 6 (n = number of the external kinematic),
    where always the "z-axis" inside these coordinate systems is the axis of revolution/translation according to the axis type (linear/rotational, see $AXIS_TYPE).
    Which axes Ex1, Ex2, Ex3 are used inside which external kinematic is defined by $ETn_AX, n = 1,..., 6 (n = number of the external kinematic).…
    Fubini
    June 18, 2016 at 12:44 PM
    Fubini
  • Y105657LL
    35
    • September 30, 2024 at 10:00 AM
    Hi,bro,how was your robot with this err? I'm encountering the same err "kss 01073", how did you solve the kss 01073 finally? Thanks for your reply
    panic mode
    1,280
    13,082
    • September 30, 2024 at 2:50 PM
    1. read the message. it should tell you what axis is affected.
    2. inspect axis, check if it is really jammed/stuck mechanically (end of travel etc.)
    3. robot does not have torque sensors. sense of torque is derived from motor current. if brake is not releasing or if one of motor phases wires is lose, current will be huge and robot will trip. the same happens when motor is bad (has short for example) or simply when axis is overloaded.
Similar Threads
  • KRC2 robot receiving "Commanded gear torque A3" stop
    • mihnea0071
    • June 11, 2021 at 9:09 AM
    • KUKA Robot Forum
  • Commmand gear torque A2
    • EmilijaS
    • December 12, 2022 at 11:04 AM
    • KUKA Robot Forum
  • Errors on kuka KRC2 Common KSD error
    • robotuser
    • March 13, 2019 at 12:20 PM
    • KUKA Robot Forum
  • Command gear torque A1 - differences between master/slave motors
    • litrmleka
    • March 11, 2022 at 8:56 AM
    • KUKA Robot Forum
  • Command gear torque error on external axis inside spline motion
    • AnthonyR
    • March 3, 2022 at 10:53 PM
    • KUKA Robot Forum
  • RSI PossCorr ABC
    • JM212
    • September 27, 2021 at 1:59 AM
    • KUKA Robot Forum
  • RSI torque command saturation according to torque prediction
    • Avi
    • July 6, 2020 at 2:03 PM
    • KUKA Robot Forum
  • torque
  • Load Data
  • KL4000
