Hi All,
I'm searching for the system-variable to enable in the config menu "Zero % Override" to TRUE or FALSE with KAREL if possible.
We want to use it with new installations of the R-30iB Plus controllers.
Hi All,
Hi mdk187,
sorry I don't know the variable.
But the implementation of "Zero % Override" is a bit hacky (like Fine and vFine):
You can only set 0% from the Teachpendant!!
You can't put 0 from a register or from plc!!
best regards
Hi PnsStarter,
I don't want to control the speed to zero by PLC. I already read that this is not possible.
In the config menu you can enable the Zero % Override option to make it possible to set speed to zero by using the + and - buttons.
I want this option to be enabled by default during an automated installation for new robots.
Display MoreHi mdk187,
best regards
