hi expert!
i have add all option neccesary into workVisual but when i open the program, this error is shown up
plz tell me how to fix this, thanks
hi expert!
Did you solve this problem ?
this seem to be complaints by WoV, not real robot. can project still be deployed? does it work?
not sure i saw this before but sound like it may be due to Visibility parameter of the program file (library) where all the functions are. if so check if &ACCESS contains V and try to remove it.
if that is the case chances are that someone was debugging and turned visibility on but forgot to change it back.
