Hello.
Can I somewhere in motosim turn off reading Macro option while simulation?
When I want to start simulation, on the line with Macro it stops and gives me alarms related with that Macro (its welding power source).
Hello.
did you try to set "test run" as you would do on robot?
use the COMMENT OUT option to comment out the macro
select the line using SHIFT+SELECT on the instruction
go to EDIT in the menu area
choose COMMENT OUT
Now it will disregard the macro
Yep, didn't work.
choose COMMENT OUT
That's the solution, a little bit time consuming but still helpfull. Thanks
