Good use of offsets on FANUC robots
  • Mister_Robot
  • April 12, 2023 at 11:23 AM
  • Mister_Robot
    19
    Hi !
    I currently have an application to apply glue to a part, this part is contained on a support. There are 6 parts per holder side by side, they are at the same distance from each other.
    The holder containing the 6 cards is gripped by the robot's gripper.
    The robot makes the movements with the holder under the glue nozzle (this nozzle is fixed).
    I programmed the glue points for 1 part and repeated by PR offset the coordinates for the other 5 positions. (OFFSET PR in Y)
    I am currently wondering which offset method to use, I have tested the 2 methods I was thinking of : OFFSET PR / TOOL OFFSET PR.
    However, I am currently wondering which one is more suitable for shifting glue points on different parts.
    As I can't learn UFRAME any other way, I learned UFRAME using the fixed dispenser and the holder held by the robot clamp, I don't know if this is the right method and if it will be a problem in the future.
    How would you go about it? Is there a difference in using these methods for this type of application?
    Thank you, I look forward to your reply.
    MR.
  • HawkME
    570
    3,270
    • April 12, 2023 at 11:58 AM
    If your tool is perpendicular to the user frame then they will both work the same way.
  • Mister_Robot
    19
    • April 12, 2023 at 1:09 PM
    Quote from HawkME
    Yes they are,
    Is one method more accurate and repeatable than the other on offsets or is there no difference?
    Thank you.
    MR
  • HawkME
    570
    3,270
    • April 12, 2023 at 2:53 PM
    The accuracy is determined by how well the frame is taught and how well the robot is mastered.
    Neither is inherently better than the other, but they do serve a different purpose. In this situation since they are perpendicular they will do the same thing.
  • Mister_Robot
    19
    • April 12, 2023 at 3:16 PM
    Quote from HawkME
    Ok great!
    Thank you :winking_face:
    MR
  • PR
  • offset Frames
  • Offset PR
  • Tool offset
