I am getting this error when going to a welding location:
How do I lower the minimum force? Also, is there a way to change the force units from Newtons to Pounds? THank you!
SpotWare has been around for a long time, what version software?
The versions I've worked with were Newtons, I used a conversion chart or app if needed force converted between Newtons, Pounds, Kilograms.
Have you verified the tip force with a pressure gauge?
I did verify the tip force. It turns out I had to install a newer version of servo gun setup through RobotStudio. The program ABB tech support gave me was out of date.
