How can i solve KRC2 error No. 287 Pc fan error.
There is one fan under the PC and one on the front.
both run fine
However, the message window shows Pc fan error.
What is the problem?
both run fine
fan itself may be turning... but fan speed monitoring may not be working. have not seen KRC2 in a long time so don't recall details anymore. normally speed monitoring is done by counting pulses that fan makes (3rd wire).
Thanks panic mode!
I solved Connect the 3rd wire and ground to the mfc card
The only time I ever recall running into that error, someone had been stripping wires with the cabinet open and a piece of wire insulation had fallen into the PC fan and jammed the blades. As soon as we removed it, everything was fine.
That's odd. How did they become disconnected?
Originally, I didn't connect it because the connector didn't match,
but there was no PC fan error.
However, after repairing and reconnecting the main board this time, the pc fan error does not disappear.
So I worked on connecting the connectors and connected them, and the pc fan error disappeared.
