Take piece to punch and stack
  • jesusvaricap
  • November 4, 2022 at 5:18 PM
  • jesusvaricap
    259
    Hello
    KRC2 KSS 5.2.14 KR2210_L150
    I have a project to take a disk metal with magnetic tool punch the disk and stack the punched disk
    so i need to use 2 cicles "FOR"
    one cicle for take the disk and heigth Z decreasing dependig of the thickess of the disk
    and other cicle "FOR" increase Z height with the finished disk
    reading older post i thik the next code can be useful
    FOR Height = 10 TO 1 STEP -1
      LIN {X 100,Y 100, Z Height} ; this won't work -- illegal KRL construction
    ENDFOR
    DECL POS _NextPos
    _NextPos = $NULLFRAME ; init to all 0s
    _NextPos.X = 100
    _NextPos.Y = 100
      _NextPos.Z = Height
      LIN _NextPos ; this works, because all the values of _NextPos were set in advance
    ENDFOR
    once finished 50 disk , make a Buzzer sound to take the disk with forklif
    any suggetions to the project ?
  • jesusvaricap
    259
    • November 16, 2022 at 3:11 AM
    Hello ,
    the probles was solved with the next code:
    DEF increasing_decreasing_Z ( )
    INI
    DECL INT TAKE,LEAVE
    DECL REAL DOWN_Z,UP_Z
    TAKE=0
    LEAVE=0
    DOWN_Z=0.0
    UP_Z=0.0
    PTP HOME Vel=30 % DEFAULT
    REPEAT
    DOWN_Z=DOWN_Z+6.35 ;thickness of the disk
    PTP P1 Vel=30 % PDAT5 Tool[1]:BendTech Base[0]
    PTP P1 Vel=30 % PDAT8 Tool[1]:BendTech Base[0]
    ;********NO_MODIFY*************
    BASE_DATA[12].X=$POS_ACT.X
    BASE_DATA[12].Y=$POS_ACT.Y
    BASE_DATA[12].Z=$POS_ACT.Z-DOWN_Z
    ;DOWN_Z_TAKE_disk_Base_12
    LIN P81 CONT Vel=.5 m/s CPDAT48 Tool[1]:BendTech Base[12]
    TAKE=TAKE+1
    ;DOWN_Z_TAKE_disK_Base_12
    PTP P7 Vel=30 % PDAT9 Tool[1]:Gripper_1 Base[0]
    PTP P8 Vel=30 % PDAT31 Tool[1]:Gripper_1 Base[0]
    UP_Z=UP_Z+6.35 ;thickness of the disk
    PTP P13 Vel=30 % PDAT36 Tool[1]:Gripper_1 Base[0]
    PTP P78 Vel=30 % PDAT37 Tool[1]:Gripper_1 Base[0]
    BASE_DATA[12].Z=$POS_ACT.Z+UP_Z
    ;UP_Z_LEAVE_disK_Base_12
    WAIT Time=.3 sec
    LIN P82 CONT Vel=.5 m/s CPDAT49 Tool[1]:Gripper_1 Base[12]
    ;UP_Z_LEAVE_disk_Base_12
    PTP P79 Vel=30 % PDAT38 Tool[1]:Gripper_1 Base[0]
    PTP P80 Vel=30 % PDAT39 Tool[1]:Gripper_1 Base[0]
    LEAVE=LEAVE+1
    ;****NUMBER THE DISK OF THE STACK*****
    UNTIL (TAKE==30) and (LEAVE==30)
    END
    just left configure I/O digitals ,sensors , activate magnetic tool, and add "Wait for" take / leave disk
    punching machine ready,disk taken TRUE, FALSE , etc
    was not possible to use the next:
    ENDFOR
    LIN { X 100, Y 100 , Z HEIGHT}
    Was nos possible to use, i try many options to manipulate Z up/down
    Z=[I]
    Z=[HEIGTH]
    any advice for the code are accepted.
    Kind regards
  • panic mode
    1,280
    13,083
    • November 16, 2022 at 3:12 PM
    of course not... aggregate is a collection of literals.
    aggregate is noted by use of curly braces.
    literal is an unnamed constant (also known as hardcoded value) and you were attempting to use "Height" which is a named value (either variable or named constant). those things don't mix, so one must use dot operator to manipulate specific element using something like this:
    DECL FRAME temp
       temp = {X 100, Y 100, z 0, A 0, B 0, C 0}
       temp.Z = Height
       LIN temp
    ENDFOR
    or
    DECL FRAME temp
       temp = $nullframe
       temp.X = 100
       temp.Y = 100
       temp.Z = Height
       LIN temp
    ENDFOR
  • jesusvaricap
    259
    • November 16, 2022 at 6:50 PM
    thanks for the info
    i ll try.
    the cicle FOR just work to decrease or increase no both , take or leave disk.
    the target is:
    take disk then (decrease Z)
    move to punt
    leave the disk punched then (increase Z)
    move to punt
    so its neccessary drecrease Z an increase Z inside a loop
  • For
  • stack
  • 5.2.14
  • punching
  • cicle
