C#_clientAppl and EthServer
  • hi everybody,
    I want to communicate with a dx200 configurated with ethernet server and a c# .net4.8 appl.
    I make this test
    - client Hercules<>dx200 : ok, the data transfer is correct
    -client c# <>serverc#(or server hercules) :ok
    -client c#<>dx200 : problem
    The socket seems open good, but when i send command i receive null answer from robot.
    Also the first command doesnt work
    "CONNECT Robot_acces Keep-Alive <CR><LF>"
    What can i do??
  • hi everybody, luckly i solve by my self the topic.
    For everybody who wants to use the c# TcpClient class with yaskawa ethernet server i suggest.
    Command="CONNECT Robot_acces Keep-Alive <CR>\r<LF>\n"
    New stream =Tcp.Client.getStream()
    Byte[] Byte_data= ... convert the string
    command in byte char
    Stream.write(byte_data,0,byte_data.length)
    The <CR>\r<LF>\n was the big enigma to find for the correct exchange😑
    Thanks, good luck!
  • Hi Baro94, Would you please send me your example project for this. Thank you so much.
