  4. Kawasaki Robot Forum
P0139 - Illegal Control Structure
  • PlasticBlaze
  • October 31, 2022 at 3:41 PM
  • PlasticBlaze
    Definitely posted in the wrong spot before :fearful_face:
    I'm currently programming a palletizing robot for a project at my work. I'm not the most experienced but think I've picked up on it okay for not having been to a training or done one before. I'm running into a problem now in my structure or formatting of my program. I can post more of my program if needed to answer the question but the section below is where the error is being thrown. It actually says line 33 of the program which is the first 'CASE TRUE' but if I comment out the section in red (not sure if color formatting works inside the code section, but its the section inside the asterisks) the program runs fine. Can you not put an IF statement in a CASE X OF scenario?
    Regardless of this, what I'm working towards is to monitor the three pallet overall heights so that the movements can be lower if there are less boxes and then dynamically change as the pallets get built. Any help is appreciated.
    .PROGRAM pal1_pat1();
    ACCURACY 5 ALWAYS
    SPEED 1000 MM/S ALWAYS
    JMOVE #abovepal1_pat1
    POINT pal1_pat1 = #pal1_pat1
    palletHeight1 = BITS(1133,7)
    palletHeight2 = BITS(1140,7)
    palletHeight3 = BITS(1147,7)
    ztotal1 = BITS(1175,9)
    zshift1 = BITS(1230,9)
    layer1 = BITS(1163,4)
    row1 = BITS(1154,3)
    xshift1 = BITS(1202,9)
    POINT pal1_place1 = TRANS(xshift1*row1,0,ztotal1*layer1)+pal1_pat1
    ACCURACY 1 ALWAYS
    POINT pal1_place1 = SHIFT(pal1_place1 BY 0,0,zshift1)
    TWAIT 0.05
    JAPPRO pal1_place1,(ztotal1+100)
    SPEED 800 MM/S ALWAYS
    LMOVE pal1_place1
    SIGNAL 39 ;  TURN VACUUM OFF
    SWAIT 1039 ; VACUUM IS OFF
    LDEPART 100
    SIGNAL 61 ; Load1 Cnt
    ACCURACY 5 ALWAYS
    SIGNAL -61 ; Load1 Cnt
    SPEED 700 MM/S ALWAYS
    JMOVE #place_approach
    5
    CASE TRUE OF
    VALUE SIG(1041):
    RETURN
    END
    CASE TRUE OF
    VALUE SIG(1042):
    CALL lane2
    END
    ;CASE TRUE OF
    ;VALUE SIG(1043):
    ;    IF palletHeight1>53 THEN
    ;        LDEPART 300
    ;        HOME 1
    ;        END
    ;    ELSE
    ;        HOME 1
    ;        END
    ;END
    CASE FALSE OF
    VALUE SIG(1041),SIG(1042),SIG(1043),SIG(1044),SIG(1045):
    GOTO 5
    END
    .END
  • Go to Best Answer
  • ericwiz7923
    25
    194
    • October 31, 2022 at 9:00 PM
    So is the issue with line 33 or the stuff you actually have commented out?
  • kwakisaki
    694
    4,770
    • October 31, 2022 at 10:33 PM
    • Best Answer
    Have a look at your IF and cross reference with the AS manual, you will see where you are going wrong.
    IF
    END
    IF
    ELSE
    END
    IF.............GOTO label
    CASE x OF
       VALUE 1:
          IF
          ELSE
          END
       VALUE 2:
          IF
          END
       ANY :
     END
  • PlasticBlaze
    • October 31, 2022 at 11:49 PM
    Thank you all. I was able to figure it out at some point during the day.
  • AS language
  • Syntax
  • illegalcontrolstructure
  • formatting
  • case
