Hello
What might be wrong because my XRC - UP6 remote mode is selected when powering on and it can not be switched off? It can be switched off by disconnecting and connecting panel cable while power is on. Then everything works like they should.
Hello
What "panel cable" are you talking about? Does the cell have a PLC? If so the PLC could be forcing remote mode on.
I believe it is called playback panel, the one that is on the controller. There might be some problem with that cable because when I moved it a bit remote light blinked. Maybe I have to try changing that cable..
