I've got maybe a noobie question but I'm stuck on this. It is also not so easy to explain so please don't be rough.
I need to change TOOL_DATA[2] on the fly regarding which object is gripped on the robot.
The problem is that gripper TCP is not in object middle point. I would like to achieve this gripper TCP = object middle point in X,Y BASE coordinates. Z is not changed.
The data that is known is on the picture attached:
-object length (can change) according to base1 origin taught with robot flange as TCP
-object width (can change)
- var1pos (position of the robot flange TCP in base 1 X) which also can change
- var2pos as above but in Y
My question is what to put into TOOL_DATA[2] to set TCP as middle of the object.
I've added some example dimmension to simplify understanding what algorithm I need.
I would be very grateful for any advice or help.
Robot is on KRC2 v5.5 (KR360).
