I have the Dir Loader set up (image below). When I toggle $FLAG[27], the src and dat files which are in the DLSourceDir[] would not get copied to DLTargetDir[]. The drive is mapped and I have connection. Is there something that I'm missing?
Thanks.
Thanks.
you are missing a lot of things.
for example why not tell us software versions that you use?
did you read the manual? are you sure your DL trigger is actually using $FLAG[27] ? did you check precondition for DL configuration changes? maybe your trigger assignment simply did not take the place yet. did you read product description and basic prerequisites before use? how about programming?
