You would think this question would be easily found online but is not. How do I describe what the next line of code is doing? I know theres a way I see it online all the time.
How make line comments in program?
cat91345 -
June 24, 2022 at 7:10 PM -
As in add an remark? If you're on a blank line you can select "INSERT" scroll over and select "Miscellaneous" then "Remark"
I had tried that before but I was using the remark under EDMC. I found the right one like you said under INST
Quote
FYI, comment under EDCMD toggles register/pr comments to be displayed or not. See images below for example:
