fanuc r 2000ib 210f offset 4 axis
  • mekeale
  • April 11, 2022 at 8:54 AM
  • mekeale
    29
    • April 14, 2022 at 8:04 AM
    • #21
    Quote from pdl
    Can you post a picture of your current master counts from the tp screen? They are under dmr_grp in the system variables.
    did not quite understand what you need, photo ...
    Images
      • 165.28 kB
      • 675 × 1,200
      • 2
  • mekeale
    29
    • April 14, 2022 at 10:09 AM
    • #22
    Display Spoiler
    • Calibrate J5 then J4
    • On robots that can have Front/Back and Up/Down configuration, calibrate J2 and J3
    can you explain where to calibrate? where is the tcp training for 6 points or the master cal?
  • pdl
    266
    1,506
    • April 14, 2022 at 3:56 PM
    • #23
    If you dig one step deeper into the master counts, we could see if they match the sheet you posted earlier. At this point I still think you need to remaster anyways.
    Your last post is worrisome. Do you have the handling tool manual?
  • mekeale
    29
    • April 15, 2022 at 6:45 AM
    • #24
    there is an instruction. I just didn't quite understand the calibration order. First, it is desirable to train the instrument and then follow theinstructions?
  • pdl
    266
    1,506
    • April 15, 2022 at 6:22 PM
    • #25
    I'll make this a very specific question:
    What Fanuc manuals do you have?
  • mekeale
    29
    • April 20, 2022 at 9:00 AM
    • #26
    Quote from pdl
    Here's what I have.
    Images
      • 165.46 kB
      • 353 × 742
      • 7
  • pdl
    266
    1,506
    • April 21, 2022 at 3:47 PM
    • #27
    Any of those mechanical unit manuals will have a complete section dedicated to each type of mastering.
    RTFM
  • mekeale
    29
    • April 22, 2022 at 6:16 AM
    • #28
    Quote from pdl
    RTFM
    I'm still busy. When I have time, I'll use your instructions first. I'll post the results.
  • mekeale
    29
    • April 25, 2022 at 7:22 AM
    • #29
    Good day everyone. Did as described in Robot-Accuracy-Enhancement . calibrated J5, J4 calibrated several times, the result is on the video. rotation around the axis by 180 degrees. In my opinion, there are no changes after calibration.
    Files
    VID_20220425_081120(0).mp4 3.08 MB – 7 Downloads
  • pdl
    266
    1,506
    • April 25, 2022 at 4:15 PM
    • #30
    Did you reteach your TCP afterwards?
    How did you teach it?
  • hermann
    405
    2,596
    • April 25, 2022 at 8:32 PM
    • #31
    Seems that the movement goes through singularity. Try a different movement, is the deviation the same?
  • mekeale
    29
    • April 27, 2022 at 8:34 AM
    • #32
    Quote from pdl
    Вы переучивали свой TCP после этого?
    Как вы этому научили?
    Yes, I taught, 6 points.
  • mekeale
    29
    • April 27, 2022 at 8:37 AM
    • #33
    Quote from hermann
    I'll try, but immediately after the calibration, I checked and filmed what happened. trained the tool in another place and rotated the 4th axis around Z, the offset is the same.
  • mekeale
    29
    • April 27, 2022 at 2:42 PM
    • #34
    may affect incorrect PAYLOAD?
  • Erik Olsen
    51
    5
    173
    • April 27, 2022 at 6:34 PM
    • #35
    Quote from mekeale
    Having very accurate payload and inertia values should help your robot's accuracy and repeatability. Would you try teaching a 4-point TCP and tell us what mean and max errors you are getting?
  • mekeale
    29
    • April 27, 2022 at 7:07 PM
    • #36
    Quote from Erik Olsen
    Is 4 points training more accurate than 6? Tomorrow I will re-master the payload and calibrate according to the above instructions, followed by 4-point training.
  • Erik Olsen
    51
    5
    173
    • April 28, 2022 at 12:10 AM
    • #37
    Quote from mekeale
    My understanding was that the 6-point tool teaching is only as accurate as a 3-point tool teaching, but provides the added benefit of teaching orientations, not just an offset. 4 point teach method is technically just a 3 point teach that picks the closest 3 points to generate an offset and informs you how far out the worst, unused 4th point was from the others.
    Somebody chime in if I am incorrect.
  • HawkME
    568
    10
    3,268
    • April 28, 2022 at 1:32 AM
    • #38
    I thought 4 point just shifted the origin. May need to double check the manual.
  • pdl
    266
    1,506
    • April 28, 2022 at 3:29 AM
    • #39
    I believe you guys have your Endians crossed.
    Erik is referring to teaching tool frames.
    HawkME is referring to teaching user frames.
    HawkME, I too did not know about this new method until I learned about it from Erik. It's in the HandlingTool manual, section 6.6.2.3.
  • mekeale
    29
    • April 28, 2022 at 5:33 AM
    • #40
    Quote from pdl
    what is the name of section 6.6.2.3.?
    Thank you
  • offset 4 axis
  • r 2000ib
