  4. ABB Robot Forum
Integrating Fronius welder into S4C IRB2400
  • Sean_MMSNI
  • April 4, 2022 at 3:42 PM
  • Sean_MMSNI
    123
    Has anyone any experience integrating a Fronius robotic welding system into an s4c robot?
    If so, what is involved? is it as simple as connecting up some I/O and installing the arcware or is there more to it? I don't want to bite off more than I can chew.
  • Nortech
    92
    • April 6, 2022 at 7:40 PM
    Hi Sean,
    I’m looking to take this on soon although mine is an S4C+. Is your fronius a TPS or TPSi?
    From what I gather, you’ll need a local net splitter cable that goes from the welder to both the wire feeder and robot controller. I think from there you should have a Rob5000 or RobTst unit in your controller that handles the interface.
    Have you started yet?
  • Sean_MMSNI
    123
    • April 7, 2022 at 8:37 AM
    We have a current welding setup that was done by another company that we bought as a complete already integrated setup. It consists of an IRB 2400L s4c and a Fronius TPS 320i. However it seems to be controlled via I/O both antilog and digital. This may be the case as the s4c doesn't have the same Ethernet connect abilities as s4c+. See attached image of interface system.
    The new setup we need is a 500 amp welding machine, it will be connected to an IRB2400L also, however I have not yet bought the robot so I could get it in either s4c or s4c+.
    I would get the company we used previous to do it only they are messing me about and not responding. So I would like to do it myself to save the hassle. However I would like to know what is involved, it might be a question I need to pass on to Fronius.
  • Nortech
    92
    • April 7, 2022 at 9:47 PM
    Ok so I worked on it today and was able to strike an arc.
    Mine is has a similar interface as yours (robTst). This unit basically connects to the AI/AO and DI/DO on the robot. Then connects to a plug on the side of the controller. Then the local net splitter cable connects to the welder and wire feeder.
    The welder has to be set up as a unit in the process file.
    It seems relatively straightforward although the unit I’m working on was previously hooked up to a fronius welder so some of the hard work was already done.
    You may need a key string or some sort of license for arc ware though?
    I have some good fronius manuals if you DM me.
  • Skooter
    169
    2,026
    • April 8, 2022 at 12:14 AM
    Don't forget Fronius tech support. I've found them helpful and quite knowledgeable about interfacing in the past.
    They sent me these files quite a few years ago that may help.
    Files
    ABB EIO for Fronius_std_BK5200single.txt 6.83 kB – 40 Downloads ABB EIO for Fronius_std_BK5250twin.txt 6.85 kB – 30 Downloads
