Weld line table
  • lilleke
  • March 22, 2022 at 8:25 AM
  • lilleke
    7
    Does anybody know how to get the weld line table to show Amps and Volts when i am using channels on welder side. Or does it work only with online control set to robot. Might i be able to move the registers from welder feedback to the ones that weld line table uses in ladder? Does anyone know what these registers are?
  • 95devils
    230
    8
    1,934
    • March 22, 2022 at 12:24 PM
    If I understand this correctly, the welder is running in job mode. The robot is a transporter for the torch. It moves to a position and start a weld. The robot moves to another position and says stop the arc. All the weld parameters are in the welder.
    How are the controller and welder communicating? DeviceNet, Profi, E I/P, etc?
    What controller?
    What welder?
    End result is probably no or if you have the time to reverse engineer it may be possible.
  • lilleke
    7
    • March 22, 2022 at 12:38 PM
    It´s a kemppi a7 powersource ,devicenet over ethernet,YRC 1000(does any other controller have weld line table?)
    And yes the welder is in so called job mode.
  • 95devils
    230
    8
    1,934
    • March 22, 2022 at 3:22 PM
    Yes, there are other controllers with weld line table.
    Not familiar with a Kempii to give you more info. Never seen one in the US on a robot.
Similar Threads
  • Robot Drifts Offf Position
    • white_raven
    • February 10, 2021 at 3:44 PM
    • Yaskawa Motoman Robot Forum
  • Deviation in position between RoboGuide and real robot
    • fmiroslav
    • January 12, 2021 at 9:50 AM
    • Fanuc Robot Forum
  • ABB S4 controller - Welding problem
    • ClaudiuA
    • October 29, 2020 at 11:33 AM
    • ABB Robot Forum
  • Moving a Linear Weld and Mframe Question
    • MaxG
    • June 11, 2018 at 8:34 AM
  • macro execution
    • KalebM
    • December 13, 2019 at 7:49 PM
    • Fanuc Robot Forum
  • I’m having troubles understanding SD for spot welding
    • RoboPeeler
    • August 16, 2019 at 2:21 AM
    • Fanuc Robot Forum
  • Motoman NX100 Editing Labels
    • Robotnewbie123
    • July 16, 2018 at 3:26 AM
  • Welding robot collision fault
    • naruto_yyc
    • May 31, 2018 at 10:33 PM
    • Fanuc Robot Forum
  • Arc welding robot 120ic with controller R30ib Collision
    • srjd
    • June 2, 2018 at 1:09 PM
    • Fanuc Robot Forum
  • YRC 1000
