First all the info on my setup:
KSS 8.5.6
KR 300 R2500 Ultra
KRC4
My problem is in regards with the access to the bases. When I go in Startup > Tool/Base Management the tool tab works fine but the base tab displays "No entries in the list" and nothing else (see picture attached). There is still the "Add" button but it doesn't do anything. However, I can still see the base when I go to change the active base in the top right of the teach pendant. Jogging in the base coordinate system is also possible. I tried reuploading a project in which I know I had access to the base tab but no success. I tried making changes in the bases in $config.dat to see if that would trigger anything, no success again. I tried adding a base through WV but again no success.
I am in communication with KUKA but they haven't provided a fix yet so I turn to this forum for help.
Thanks,
