GOOD Moornig everybody!
I need a litle bit of help
i need to download this c software version 23010KAE..... Have anybody this version?
THANKS IN ADVANCE
THANKS IN ADVANCE
You have asked for this in a previous thread.
You would be better contacting Kawasaki Robotics Incorporated (KRI USA) for this firmware as it's North American Spec.
Why do you think you need to replace the firmware?
Thanks for your answere , becouse i need to change the teach pendant and download the tp firmware version......
Ah right, I only have Europe spec unfortunately.
Unless someone else can here can provide it then your best bet is KRI directly I think.
ok . THANK YOU VERY MUCH
In your other post you mentioned you had AS and TP already and were having trouble with the Servo.
Is this not the same controller?
Hello , I solved the problem .
I could doownload a european version. tp software, servo software and as software and is ok
Thanks a lot
Being from the UK, I've never been in a position to load in European to a N.American Spec before, so unsure if it all works ok.
So it's good to know for future reference if it works ok with no issues.
Thanks for posting back our result.....
The robot works ok no issues
thanks!!!
hello Good afefternoon everybody
I am triying to back to life a ux 120 and i have any doubts.....
ux 120 contro C and ux 150 control c is the same robot? only change the software? Could i Install an ux 150 control c software in an ux 120?
A lot of questions.....Thanks in advance!!!
If you are bringing back to life UX120, why talk about UX150, they are not the same.
If they were the same, then they would both be called the same UX variant.
You haven't mentioned the most important thing, what controller is it.
SORRRY... both of them are c control
What C controller, there are about 15 versions?
ux 120
control C 42F-A001
So you have 2 UX120 and 2 C42 controllers......why are you talking about UX150?
becouse i have in the company a lot of ux -150... and i would like that this ux -120 install the same software thant ux 150 , to share mft, cards etc... in case i need it
It should do.
i only have ux 150 control C sofware
could i install it in the ux-150 ?
thanks !!
could i install it in the ux-120 ?
thanks !!
UX120 and UX150 use same motors, only in software does distinguish which model.
So if you install correct SV software for model to be used then it should work.
