Thank you very much 💝
Install new software
Omid1365 -
January 16, 2022 at 10:44 AM -
I had this problem yesterday @omid, i replaced H.D.D with other H.D.D for test reason, and after i installed it's H.D.D again, KRC had fail startup and showed exactly the message that you have.
It Just need to install KSS again.
I renistall KSS but have same problem ..
When I've encountered this issue in the past, usually the steps I follow are, in approximate order:
- re-install KSS
- remove the hard drive, connect to another computer, and use disk-scanning tools
- try cloning the old hard drive to a new (hardware-compatible) drive using dd, CloneZilla, Acronis, etc, then install the new drive
- possibly re-install KSS
- Check motherboard for damage, in particular swollen capacitors
- Remove and re-seat RAM
- check all hard drive cables
- re-install Windows and then KSS (must be in that order)
- must be the correct KUKA version of Windows
- replace RAM
- replace motherboard
A green led in MFC3 CARD not blinking ..
for robot to work, many things need to be done correctly.
reinstalling software (if done correctly) can remedy problems - if the problems are software related.
if the problem is with hardware, reinstalling software will make no improvements.
just let follow the sequence what happened (finding the post is your job)!:
No problem..I give you the right to be angry
KSS version is v5.6.8..
We did not have any problems, but the factory electricity was cut off twice because it was snowing and we had this problem
My guess:
some files could not be saved and therefore you have this problem
Ergo:
checking hdd (and file management)
Result:
This was not done
To Do:
check SkyFire's suggestion from post #44 item 2
and RESPOND as asked millions of time
Remember: we want to help YOU
DO AS REQUESTED, OR LEAVE IT
Following post #26
where are the requested windows event files?
(I could not find any!)
Hello MOM
For HDD test Im put another HDD from other robot on pc and cross 3 again appear I reinstalled kss and the same problem appeared again
I asked for the same hdd you had the problem with - otherwise I could have used one of mine
QUESTION: do you want really help
yes:
answer questions
no:
tell us as some fairy tails
We can only answer to question yes
