every time i start the robot, it jumps to the last instruction, which is th end. What would make it do this?
Robot keeps jumping to end of program on every program, why?
cat91345 -
December 21, 2021 at 3:04 PM -
Conditional instructions moving the cursor to an instruction near the bottom of the job. Would be my guess.
It is depends on your program that write,
One of reasons that "95devils" told is use the conditional instruction same as IF, when the conditional isn't correct, it doesn't do the instructions between the conditional instruction and jump to END, other reason is the position of cursor when you start the job, when it is on the end of the job it don't run job and go to end.
When you don't have any MOV instruction, after start the job it will do the job very quick and stop on the END ( if you use jump instruction it will do the job again)
For more help you must send your job for check.
Need to see the code.
