How to fix joystick disabled error ??
Joy stick disabled problem for ABB
Suhas Mulay -
November 18, 2021 at 8:52 PM -
Anyone please tell me
Suhas Mulay
November 18, 2021 at 8:53 PM Changed the title of the thread from “Joy stick disabled problem” to “Joy stick disabled problem for ABB”. -
If it happens when the controller is first turned on, the most likely cause is the joystick was not centered during the joystick test of the teach pendant's self-test routine. At power on, make sure nothing is touching the joystick, the handle is centered, and there is no debris stuck in the joystick's protective boot.
Please note that you will get faster, more specific responses if you include more information about your equipment.
Thanks...but how to overcome this issue
replace the Joystick, mostly a connection problem inside the Teachpendant
We replaced the joystick on many of the ABB robots, they wear out for sure
Suhas,
As I understand from the topics you have opened, you have just acquired the robot. You don't understand much about robots. I think you should practice a little. Mix youtube videos, tutorials, manuals. The things you see as a problem may be coming from you because you are using them wrong / you may not be able to do it.
Joystick devre dışı hatası nasıl düzeltilir?
robot açılırken test esnasında joystick orta konumda olmasına rağmen bu hatayı veriyorsa, joystick sökülüp yaylar ve yüzeyler temizlenebilir. daha önceden benim de başıma gelmişti ve düzeldi. denemekte fayda var..
