Rj3iB controller hooked up to a Fanuc Arcmate 120iB with lincoln powerwave 455m. The weld equipment hasnt been used in years and while i turn it on and lights are all green as soon as i try to feed the wire at all the Robotic Wire Drive LED flashes red in a sequence of 6 flashes, pause, 3 flashes, pause, 1 flash, pause, 1 flash, pause then back to green for a few seconds before repeating.
I plugged the robot into a different controller/weld equipment combination nearby and it worked perfectly so I know the robot and feeder themselves are working. It recognizes there is weld equipment and it is turned on because I don't get a weld EQ error, there is no error on the teach pendant at all, actually.
My theory is that the controller and the cabling is all fine because there are no teach pendant errors and the problem lies with the weld equipment. If I could figure out that flashing light then I think I would know what to do but no user manual for it has any way to decode the sequence and i can't find a service manual for a normal 455m (455m STT and 455m with PowerFeed10 I can find but neither has been helpful)
