We got old ABB IRC5 R120 with Profinet Anybus card for connecting to Siemens S1500. This robot has Roboware version 5.15 . Anyway I tried following what the Profinet manual suggested but the screen on RobotStudio2021 looks way diffrent and with diffrent options then what it is suggested.
First problem is that Service port shows no light when connected with ETH cable neither does PC recognize any plugged cable. LAN port seems to work so I could connect to RoboStudio. When i connect PROFINET cable from PLC to ABB field bus port there is also no light, neither does the PLC detect any devices when i installed GSD file.
Could someone suggest what could be done, I can't find any useful options either on FLEXpendat to at least set PROFINET IP etc.
Thank you.
