If I have IRC5 connected as Profinet device to Siemens S7 plc, and a bit in the receive area for the IRC5 is always set high from
the code of the S7 plc. When the Profinet cable is unplugged, will it have value 0 (or default value)?
I would use this for check if communication with S7 plc is still ok.
Value of inputs from profinet when communication goes down
Plc_User -
November 20, 2018 at 3:41 PM -
Try the function IOUnitState to evaluate the status of the connection.
I just did that
I mapped the system I/O signals to profinet
changing the logic of the Quick STOP/ Soft STOP / STOP signals
so now the PLC must send 1 to those signalsThe I/O signals take the default value wen the cable is disconnected or communicaation problem occurs
Now those signals have to functions, I can STOP the robot using those signals and also detect a cable unplugged
That robot STOPS because the signals are missing -
Ok, Thanks
I have some signals configured as analog input that come from Profinet communication sent by Siemens PLC.
I have filled in a default value different from 0.
When connection is ok, value of f.i. 56 is sent and received ok in the robot.
When I pull out the profinet cable I get value 0 in the robot.
What is the default value then used for?
How can I achieve that the default value is used when the connection is down?Thanks.
What are your other signal parameters settings?
Like min value, logical value, etc.
