What tooldata/tool that i need to use when defining work object? Help. is it always tool0 or use the tooldata that we have created for installed tool?
work object
hazril3 -
September 1, 2021 at 11:25 AM -
Most likely never tool0, there is no well defined point on the flange for teaching the work object. Certainly use the installed tool, providing that you have defined it well.
When the robot tool lacks a good sharp physical TCP, usual practice is often to mount a temporary (fairly sharp) pointer to the robot tool, set that pointer up as a TCP, and then use that pointer to get better precision in touching off the three points for creating the Work Object.
Backing up what he just said, I have used threaded rod ground to have a good point, then inserted into threaded hole. Take appropriate care to not injure yourself or others. I have even taped a pen to the end effector or fixture in order to teach.
Yeah. A lot of integrators I've have a standard "pointer" attachment, and make their end effector designers include a mounting point (usually a threaded hole) on every end effector, located someplace that makes the pointer useful.
A lot of experienced robot programmers will carry one of their own, usually with a magnet mount, in their personal tool box.
