Hello, I am attempting to get servos on but I receive this alarm in the process:
"If the sub-code 1nxx is displayed..." My sub code is 2101 so I am unsure how to proceed.
Any help would be appreciated.
This has been solved.
The FSU was configured to use the ASF02 expansion board however that board was not actually installed in the cabinet. Setting the Safety IO board to "Not use" fixed the issue.
where did you do the setting?
Is it possible send the picture from your change to solve the problem.
In Maintenance mode. In Safety security level. SYSTEM, SETUP, OPTION FUNCTION, SAFETY I/O BOARD. Press SELECT on DETAIL. In this screen it will display NOT USE if no board is being used or ASF02 if using the board.
