Hi all,
I am trying to make a connection between PC and the virtual controller within Roboguide using modbus.
I have access to a manual titled,
"R-30iA/R-30iA Mate CONTROLLER Modbus TCP Interface"
Under, Setting Up a Modbus TCP Slave,
It says to follow this sequence:
1. Press MENUS.
2. Select I/O.
3. Press F1, [TYPE], and select Modbus TCP. You will see a screen
similar to the following.
However, on my Roboguide software, when I follow the above sequence, I do not see Modbus TCP option. Did I miss something. I am using a trial version of the Roboguide software that is valid for one month. Could it be that this version does not include the modbus option by default.
looking for any help, pointers in this regards.
thanks,
zahid
