Every time I turn the robot off and on again, it goes back to the state of the last backup performed, losing the updates that were made after that, such as the production count and changes to the program. Please, has anyone been through this?
abb irb 6400 M97 robot missing production counter and schedule changes
kennedyrsb -
May 4, 2021 at 3:35 PM -
- Go to Best Answer
You need to change the batteries in the controller which keep the memory live while mains is shut off.
Save the program before shutting down if you make changes. Could be setup to load the program at boot up.
- Best Answer
Good point Skooter. That would be in your sys.cfg file in a backup. Most likely would be saved to and loaded from the HOME directory.
O problema foi resolvido, graças a todos os que contribuíram.
