Are Alarm Recovery Choices (i.e. "Retry Weld...", etc.) customizable or removable?
  • Liquidmaximo
  • March 29, 2021 at 5:19 AM
  • Liquidmaximo
    Menu -> Alarm -> Recovery
    This reads as no faults exist unless there is a recovery option available. This can occur if the WELD COMPLETE was not received from the weld controller. It lists the ERROR AND ACTION. F4 will pull up the choices. For weld Faults, I'm given two options:
    1. Retry weld and continue program
    2. Skip weld and continue program
    Can the choices be modified or even removed/deleted? It might seem odd, but I don't want these options directly on the robot controller itself (especially option 2). I can't find much information online regarding Alarm Recovery. I have several theories and ideas, maybe one of you know for sure. I feel like this might have a simple solution but I'm not seeing it. Thanks in advance for any help.
    Additional Info if helpful:
    SpotTool+
    v8.3
  • pdl
    272
    1,549
    • March 29, 2021 at 7:56 PM
    I would do a search for "Menu Utility." I think that is what you want. To see if your robot already has it, check under MENU > SETUP
  • Liquidmaximo
    • March 31, 2021 at 11:53 PM
    Quote from pdl
    First, thank you for your response. From the brief research on "Menu Utility", it could be what I'm looking for. Unfortunately, I don't see this option in my teach pendants. It appears to be a paid option; am I out of luck or is there another way to modify the recovery options?
  • Srt_424
    7
    • April 2, 2021 at 5:12 AM
    Try Menu/Utility/Setup Servo gun if using Spot tool software.
    You should be able to configure the weld preferences.
    Srt_424
