G'day All
Interfacing a Kawasaki robot to controllogix using ethernet IP. Looking for setup logic, maybe eds file.
G'day All
What Controller?
Software Ethernet IP?
Hardware Ethernet IP? - If so what is the board you're using?
Master or Slave?
G'day All
We just have ours set up as generic modules
- RS050N Robot
- RS050N Robot
That should be a non-factor.
Great Thanks
What Controller?
Master or Slave?
One other question, does the RS050N robot use AS programming. I have the manual but do not want to waste time reading it without knowing. Thanks
Yes, every kawasaki robot is using AS programming. You need to connect with the terminal and start writing the programs in AS language
