Can't Program in an active user Frame
  • REC TECH
  • February 23, 2021 at 8:25 PM
  • REC TECH
    I have a R-J2 robot that I can not seem to get to save a position in the active used frame. I set the user frame to 1 ( Shift Cord and set Uframe to 1) but when I then save a position, it saves that position in Uframe 0 ( world). Is there a variable that I am missing somewhere that "activates" the use of user frames, so every saved position does not default back to user frame 0 ( world) ? We can not do offsets in a frame, if we can not save position in a user frame. Thanks in advance for anyone that can tell me how to fix this.
    UPDATE:
    I found the below information about $USEUFRAME that is exactly what my robot is doing ( using zero no matter what the frame number is set to) but I do Not have a $USEUFRAME in my system variable. Anyone know how to turn that on?
    The system variable $USEUFRAME defines whether the current value of
    $MNUFRAMENUM[group_no] will be assigned to the positionís user frame when it is being
    recorded or touched up.
    • When $USEUFRAME = FALSE , the initial recording of positions and the touching
    up of positions is done with the user frame number equal to 0, regardless of the value of
    $MNUFRAMENUM[group_no].
    • When $USEUFRAME = TRUE , the initial recording of positions is done with the positionís
    user frame equal to the user frame defined by $MNUFRAMENUM[group_no]. The touching up
    of positions must also be done with the positionís user frame equal to the user frame defined by
    Edited once, last by REC TECH (February 23, 2021 at 9:02 PM).
  • SHalley
    • May 10, 2023 at 4:45 AM
    Hi Mate,
    Did you end up solving this one? I'm having the same issue.
    Thanks!
Similar Threads
  • system variables for userframe position
    • zhaoxiang chen
    • July 22, 2020 at 4:35 PM
    • Fanuc Robot Forum
  • Making decisions based on current robot position
    • D_DeVanney
    • December 3, 2018 at 8:38 PM
    • Fanuc Robot Forum
  • Help changing user frames programatically
    • mbartlett
    • August 6, 2019 at 6:22 PM
    • Fanuc Robot Forum
  • Fanuc iRVision Off-Axis Rotation Correction
    • Nick1324
    • January 14, 2020 at 5:21 PM
    • Fanuc Robot Forum
  • Odd Step Behavior
    • Robo_Eng_13
    • May 14, 2019 at 7:47 PM
    • Fanuc Robot Forum
  • Roboguide virtual and real robot calibration
    • ORDEP81
    • August 13, 2018 at 4:14 PM
    • Fanuc Robot Forum
  • Go "home" from inside a program.
    • NovaFlatline
    • June 12, 2018 at 7:16 PM
    • Fanuc Robot Forum
  • ABB S4 Create a User Frame
    • andrewklay1
    • November 29, 2017 at 9:04 PM
    • ABB Robot Forum
  • user frame
  • world frame
  • active user frame
  • active user frame always world
