How to Repeat a group of movements
  • Joe27
  • February 22, 2021 at 1:26 AM
  • Joe27
    Hi All,
    I have a Kuka KR4, with a compact controller that I am trying to do some basic programming on. I'm fairly new to this, so this may be a basic question for all, so apologies if that is the case
    I want to redo a movement in multiple locations and not sure the best way to set this up. Think of it like I have a group of movements that traces out the letter "W". I want to do this multiple times in the workspace with a new start point for each "W".
    At present I have defined the movement in the Base coordinate system, but not sure how to make it such that I can repeat the movement path with a new starting point (without doing each "W" as a new set of point).
    I'm sure there is an easy way, but I am not sure where to start searching to do this. Any pointers would be much appreciated
    panic mode
    1,278
    13,079
    • February 22, 2021 at 1:34 AM
    there are different ways to go about it:
    1. recalculate positions
    2. offset base
    3. use relative motions
    SkyeFire
    1,051
    9,423
    • February 22, 2021 at 3:21 PM
    An array of points:
    DECL FRAME Array[5]
    Array[1] = {X 0,Y 0,Z 0,A 0,B 0,C 0}
    Array[2] = {X 100,Y 0,Z 0,A 0,B 0,C 0}
    Array[3] = {X 100,Y 100,Z 0,A 0,B 0,C 0}
    Array[4] = {X 0,Y 100,Z 0,A 0,B 0,C 0}
    Array[5] = {X 0,Y 0,Z 0,A 0,B 0,C 0}
    DECL INT Index
    FOR Index = 1 TO 5
      LIN Array[Index]
    ENDFOR
    To do the same with Base offsets:
    DECL E6POS MyPoint
    MyPoint = $POS_ACT_MES ; set to current physical position
    FOR Index = 1 TO 5
      $BASE = BASE_DATA[1] : Array[Index] ; active base is BASE_DATA[1] plus the offset
      LIN MyPoint
    ENDFOR
    Point Offsets:
    DECL E6POS MyPoint
    FOR Index = 1 TO 5
      LIN MyPoint : Array[Index] ; point plus offset
    ENDFOR
  • Joe27
    • February 22, 2021 at 11:40 PM
    Thanks all - from a little more searching, I found a similar example here using the base offset:
    Kuka Subprogram/array
    So I adapted that code for my application, and it seems to be working - now I just need to adapt it to add the real code/offsets etc
    Thanks so much for the help
    &ACCESS RVP
    &REL 2
    DEF DB_BC_FOLD_TEST_base_off()
      DECL INT X,Y; variable used for loop counter
      DECL INT X_Max, Y_Max ; variables that specify number of repetitions
      DECL REAL dX, dY ; offsets
      DECL FRAME Ofs ; this is the base offset
      dX = 0 ; X-offset
      dY = -3; Y-offset
      X_Max = 1; one row
      Y_Max = 2 ; four columns
      Ofs=$nullframe
      ;Base 3 is the original values for the Fold Base
      ;Base 2 is the one that is offset and moved each time
      BASE_DATA[2] = BASE_DATA[3]; ReSet Base 2 (from 3) incase the program was interrupted
         FOR X=1 to X_Max
           FOR Y=1 to Y_Max
              Ofs.X = (X-1)*dX
              Ofs.Y = (Y-1)*dY
              BASE_DATA[2] = BASE_DATA[2]:Ofs ; Offset Base[2]
              DB_test01(); Deburring program (for 1 channel)
           ENDFOR
         ENDFOR
      BASE_DATA[2] = BASE_DATA[3]; Reset Base 2 to the original values
    END
    Edited 3 times, last by Joe27: cleaned up code (February 23, 2021 at 2:20 AM).
  • movement
